Is there a way to audit and/or disable user API tokens?
For example, we need to prevent long-lived user API tokens; We need to ensure API tokens expire before 90-days.
Audit and/or Disable User API Tokens
Hey Kevin @kevin.murphy,
You can try registering a private app with a Scoped OAuth functionality. And then fetch user tokens with only audit.read scope. This scoped token can then be used to access the audit API
Hope that helps answer the question!
Was this helpful?
- YES
- NO
0 voters
Thanks - Looks like user tokens may not be available yet…
https://developer.pagerduty.com/docs/ZG9jOjExMDI5NTY2-audit-records-api#resources-tracked
Hey @kevin.murphy, can you please help me understand your use case and share some more context? I am not sure I understand when you mentioned user tokens are not available yet? Do you mean User API keys by user tokens? We do have a way to disable User API token creation for your PD subdomain if that’s what you are looking for. Happy to also jump on a call with you if you can share your details. Thanks!
Hi @nakul.bhagat - We have a requirement to rotate access keys every 90-days. So, I’m looking to audit the “API Access Keys” for all users. If any keys were created more than 90-days ago, delete/revoke them.
Hey @kevin.murphy, unfortunately there is no API available to audit the API Keys. There is a manual and tedious process I can think of where, if your are admin/owner, you can go to each of the users page and go to the User API Keys page, where you will find the data rendered in the table giving you details on when the User API Key was created and when was it last used.
I would recommend you to look at using the Scoped OAuth User Tokens, where they expire in 24 hours automatically. And on top of that you do get the ability to even revoke all the tokens, if and when needed. And in unforeseen circumstances even delete the Scoped OAuth client and recreate a new one within the App that you’d created/registered. You can find more details here.
Was this helpful?
- YES
- NO
0 voters
Thanks @nakul.bhagat. OAuth is what I have switched to. I’ll just update our internal docs to not use API Keys.
